Oliver Travel Trailers
Small Travel Trailers
Total Length : 18' 5"
GVWR : 5000 LBS.
1 Axle
Seats 6 / Sleeps 3
2024 Legacy Elite
Small Campers
MSRP Starting at $87,200
The Oliver Legacy Elite is our smallest fiberglass travel trailer. This single axle model measures 18' 5" in length, with an insulated double-hulled shell, making it all four seasons camping ready. The Legacy Elite is available in the standard floor plan with a 74″ x 52″ bed, a complete kitchen, and a full bathroom that includes a toilet, vanity, sink, and shower.
Legacy Elite campers have many standard features, but if you want more, look at our new premium and platinum packages for an even greater camping experience.
Single Axle 20 Foot Small Travel Trailer
Awesome for Couples
Pet-Friendly
Lithium Batteries Available
Solar Power Available
Four Season Camping Ready
Porcelain Toilet
20 lb. Propane Tanks
Tankless Water Heater Available
Fiber-Granite Countertops
Powered Awning
Easy to Tow
Built to Last Generations
Specifications
GVWR: 5000 LBS
Dry Weight (Approximate Of Base Model): 3700 Lbs
Tongue Weight (Approximate Of Base Model): 370 Lbs
Outside Length: 18' 5"
Outside Height To Top Of A/C: 9' 2"
Outside Width: 6' 6"
Inside Height: 6' 1"
Inside Width: 6' 2"
Fresh Water Tank Capacity: 32 Gal Design Capacity
Grey Water Tank Capacity: 32 Gal Design Capacity
Black Water Tank Capacity: 15 Gal Design Capacity
Seats: 6
Sleeps: 3
Floorplan Layout
The Legacy Elite standard floorplan offers generous dimensions with an outside length of 18' 5", an outside width of 6' 6", and an approximate dry weight of 3,700 lbs.
There's plenty of room and storage for short and extended trips, with dedicated sleeping space, a convertible dinette/lounging area, a full kitchen with all the amenities, and a full bathroom with a shower.
Rear Seating Area Converts Into A 52" X 74" Bed
Side Dinette Converts into a 71" x 23" Bed
  • Small Camper Floorplan Diagram with Seating and Sleeping Areas
  • Legacy Elite Seating Diagram
  • Legacy Elite Sleeping Diagram
Standard Features Base Model Features & Components
Legacy Elite small campers stand out with top-of-the-line standard features and optional components that shine during your adventures. Discover why the Oliver is the best camper your hard-earned money can buy.
Exterior
Interior
Living Area
Electric
Hull Features
Full Custom Molded Interior and Exterior Insulated Shells Standard
Transportation Grade Gel-Coat with UV Protectants Standard
Custom Molded Fiberglass LP Cover Standard
Custom Molded Fiberglass Spare Tire Cover Standard
Plumbing, Holding Tanks and Drain Pipes enclosed between shells with heat to diminish freezing Standard
32 Gal. Design Capacity Fresh Water Tank Standard
32 Gal. Design Capacity Grey Water Tank Standard
15 Gal. Design Capacity Black Water Tank with pressure flushing system for the Tank Standard
Chassis Features
Heavy Duty Anode Protected Aircraft Grade Aluminum Frame Standard
Dual Gas Shocks on Single 5000 Lbs. Dexter Leaf Spring "Nev-R-Lube" Axle (new on 2022 models) with “Nev-R-Adjust” 12″ Electric Brakes for Exceptional Control and Braking (Now with Bronze Bushings & Grease Zerks) Standard
Premium Aluminum Rims with 10-ply Tires Standard
Full Size Spare Tire with Aluminum Wheel Rim Standard
7000 Lb. Cast Iron Bulldog Hitch Standard
Black “Rock Guard” Wheel Well Lining Standard
Hide-Away Aluminum Storage Bumper with Black/Grey Water Drain Attachment Located Inside Standard
Exterior Features
20 Lb. LP Tanks x2 Standard
Fresh Water Fill Hook-Up Standard
City Water Direct Hook Up Standard
Fold Up Aluminum Double Entry Steps with Grip Tape Standard
Custom Enclosed Slide-Out Battery Storage (Includes 2x 12 V Batteries) Standard
Marine Grade Shore Power Connection with 25′ Cord Standard
Outside 11Ov GFI Protected Outlet w/ Cover Standard
Exterior LED Ground Lighting Standard
LED Brake Lights Standard
LED Marker Lights Standard
High Mount Porch Lights x2 (1 on Each Side) Standard
Custom Rear High Mount Oliver Sign Standard
Convenient Exterior Entry Handgrip Standard
Powered Pro Awning with LED Light Strip, Wind Sensor, Remote, & Upgraded Canvas Standard
Outside Wash Station Standard
Three Point Power Stabilizing System Standard
Sliding Thermal Pane Windows with Sliding Screens x4 Standard
Propane Easy Access Port Standard
Interior Features
Fiber-Granite Countertops, Tables, and Accents Standard
Full Surround Over-Head Lighted Storage Compartments Standard
Lighted Full Height Wardrobe Closet Standard
EZ Winterizing System Standard
MaxxFan Deluxe Remote Control RV Ventilator System Standard
2 Way Self Igniting Water Heater, DSI 6 Gal Standard
Fresh Water Pump 55 PSI, 3.0 GPM Standard
Dometic High Efficiency A/C (Approx. 11,000 BTU) Unit & Wall Mount Thermostat Standard
LP Ducted Furnace Standard
Monitoring System for Tanks and Batteries Standard
White Day/Night Window Treatments (Excludes Bathroom) Standard
Overhead LED Lights Standard
LED Courtesy Floor Lights Standard
Reading Light Package Standard
Frosted Upper Cabinet Doors in Cabin and Bathroom Standard
Water Accumulator Standard
120-Volt Receptacles Standard
12V/5V Dual Charging Stations Standard
Dinette, Seating, Sleeping and Storage Features
Side Dinette (seats 2) Converts to Single Bed Standard
Rear Dinette (seats 5) Converts to 74″ x 52″ size bed on Standard Floor Plan Standard
Kitchen Features
Flush Mount 2x LP Burner Stove Standard
2-Way Refrigerator (12V, 120V) Standard
High Rise Swivel Faucet Standard
Custom Designed Storage Drawers with Dovetail Joints Standard
Stainless Steel Microwave Standard
Bathroom Features
Molded Vanity with Toiletry Storage Standard
Dometic 311 Toilet (Low Profile with Porcelain Bowl) Standard
Exhaust Fan Standard
Brushed Nickel Faucet with Pull Out Shower Wand Standard
Sliding Frosted Privacy Window with Screen Standard
Mirror Tinted Door Standard
Waterproof Toilet Paper Compartment Standard
Towel Bar and Hook Standard
Central Heat Vent Standard
Safety Features
Fire Extinguisher Standard
Smoke Detector with Alarm Standard
Carbon Monoxide Detector with Alarm Standard
LP Leak Detector with Alarm Standard
Oversized Emergency Egress Window with Screen Standard
Electric Features
120V Outlets on GFI Protected Circuit Standard
Progressive Industries EMS Surge Protector Standard
Converter with Built in Charge Wizard Standard
Multiple Charging Stations, 12V DC marine-grade female socket & dual USB 5V adapters Standard
Exterior Plug & Play Port for Portable Solar Panels (Requires Factory Installed Solar Package) Standard
Entertainment Features
24” Flat Screen LCD TV (120V, requires Inverter) Standard
Radio with FM and AM Dual Zone Audio Output, DVD, CD/MP/WMA/MP4, USB, Bluetooth and Remote Control Standard
Custom Mounted Speakers x4 Standard
Dual Exterior Coax for Portable Satellite/Cable Standard
Solar Panel is Available as An Option for Off Grid Camping
Go Beyond Camp SitesExtend Your Stay & Your Enjoyment
We have incorporated the top features from our model's add-ons and upgrades from previous years into our new packages to enhance your camping experience and extend your stay. Our improved packages help make the most of your time outdoors.
View Premium & Platinum Packages
Walkthrough Video
Explore the features of the Legacy Elite with our detailed video walkthrough.
3D Virtual Tour
Small Camper Virtual 3D Tour
Take a captivating 3D Virtual Tour of the Legacy Elite online.
Take the Factory Tour
Visit our showroom or contact our sales office at 1-888-526-3978 for more information.
Schedule A Factory Tour
Find an Oliver Near You
See an Oliver Camper
You can see one of our little compact travel trailers using our See An Ollie program.
See An Oliver
Start Your Adventure Today
Are you ready to create the perfect travel companion for your next adventure?
Get Started
graduation-hatfilm-play
