Oliver Travel Trailers
Compare Models
Elite vs Elite II Comparison
We put together a comprehensive comparison on the latest models.
Hull
Legacy Elite
Body
Four-piece molded fiberglass with insulation between shells Four-piece molded fiberglass with insulation between shells
Insulation
Double Hull, Thermal Break with Insulated Double-Sided Radiant Barrier Polyethylene Bubble + Radiant barrier + Vapor Barrier + Air Gap Barrier. Double Hull, Thermal Break with Insulated Double-Sided Radiant Barrier Polyethylene Bubble + Radiant barrier + Vapor Barrier + Air Gap Barrier.
Floor Plans
Standard (74" x 52" Bed) Floorplan Standard (75" x 79" Bed) or Two 75" x 30" Twin Beds Floorplans
Exterior Length
18' 5" 23' 6"
Exterior Height - Top of the A/C
9' 9' 7"
Exterior Width
6' 6" 7'
Interior Height
6' 1" 6' 6"
Interior Width
6' 2" 6' 7"
Dry Weight (Base)
3,700 lbs. 4,900 lbs.
GVWR
5,000 lbs. 7,000 lbs.
Net Carrying Capacity
1,300 lbs. 2,100 lbs.
Fresh Water Tank Capacity
Design Capacity 32 Gal. Design Capacity 32 Gal.
Grey Tank Capacity
Black Tank Capacity
Design Capacity 15 Gal. Design Capacity 15 Gal.
Furnace, Water Heater, & A/C Package
Standard Package Includes - Suburban DSI 6-gallon Water Heater and Dometic Penguin II High Efficency 11k BTU A/C
(Optional Upgrade Package Includes - Truma Aquago Comfort On-Demand Water Heater with Electric Antifreeze Kit and Truma Aventa Eco A/C)
Chassis
Legacy Elite
Axles
Dual Shocks on Single 5,200 Lb. Dexter "Nev-R-Lube" Leaf Spring Axle Quad Shocks on Tandem 3,500 Lb. Dexter "Nev-R-Lube" Leaf Spring Axles
Brakes
“Nev-R-Adjust” 12″ Electric Brakes (Now with Bronze Bushings and Grease Zerks) "Nev-R-Adjust®" 10" Electric Brakes
Front Tongue Jack
Electric Powered Electric Powered
Stabilizer Jacks
Electric Powered x2 Electric Powered x2
Wheels
Premium Aluminum Rims with 10-ply Tires w/Black “Rock Guard” Wheel Well Lining Premium Aluminum Rims with 10-ply Tires w/Black “Rock Guard” Wheel Well Lining
Spare Tire
Full Size Spare with Aluminum Rim Full Size Spare with Aluminum Rim
Hitch Connection
7,000 Lb. Cast Iron Bulldog Hitch (2") 7,000 Lb. Cast Iron Bulldog Hitch (2")
Frame
2" x 5" Box Tube Aluminum Frame 2" x 5" Box Tube Aluminum Frame
Rear Bumper
Hide-Away Brushed Aluminum Storage Bumper with Black/Grey Water Drain Hose Hide-Away Brushed Aluminum Storage Bumper with Black/Grey Water Drain Hose
Exterior
Legacy Elite
Exterior LP Gas Port
Exterior Quick Connect Ports (Now Standard) Exterior Quick Connect Ports (Now Standard)
Outside Wash Station
Standard Standard
Battery Storage
Custom Enclosed Slide-Out Battery Storage (Fits Up to 2x Batteries) Custom Enclosed Slide-Out Battery Storage (Fits up to 4x batteries)
Deep Cycle Batteries
2x 12 V Batteries. (Option 6V AGM Batteries and 12V Lithium Batteries are Available.) 4x Group 27 Deep Cycle 12V Batteries. (Optional 6V AGM Batteries and 12V Lithium Batteries are Available.)
Propane Gas Tanks
20 lb. x2 LP Tanks 20 lb. x2 LP Tanks (Housing Can Accomodate Up To 30 lb. Tanks)
Exterior Lighting
High Mount LED Porch Lights, LED Ground Lights, LED Rear Brake and Backup Lights. Custom Rear High Mount LED Oliver Sign. High Mount LED Porch Lights, LED Ground Lights, LED Rear Brake and Backup Lights. Custom Rear High Mount LED Oliver Sign.
Awning
Powered Girard Awning with Wind Sensor & LED Light Strip. Powered Girard Awning with Wind Sensor & LED Light Strip. (Option for Additional Awning on Street Side)
Windows
3x Dual Pane Thermal Sliding Windows with Sliding Screens and Rear Emergency Egress Window 4x Dual Pane Thermal Sliding Windows with Sliding Screens and Larger Rear Emergency Egress Window
Steps
Fold Up Aluminum Double Entry Steps with Grip Tape Fold Up Aluminum Double Entry Steps with Grip Tape
Interior
Legacy Elite
Interior Lighting
LED Lights LED Lights
Window Shades
Day/Night Window Treatments (Excludes Bathroom) Day/Night Window Treatments (Excludes Bathroom)
Digital Monitoring Systems
Wall Mounted, See Level II Monitoring System for Tanks and Battery Voltage Wall Mounted, See Level II Monitoring System for Tanks and Battery Voltage
Vent Fan
Maxxair Fan Deluxe RV Ventilator System with Remote Control Maxxair Fan Deluxe RV Ventilator System with Remote Control
Floor Construction
Gel-coat Over Fiberglass Molded Inner Shell Gel-coat Over Fiberglass Molded Inner Shell
Interior Wall Construction
Decor Packages
Desert, Midnight, or Storm Decor Packages that include Fiber-Granite Countertops, Premium Vinyl Flooring, and Cloth Uphostery on Cushion (Options available for Upraded PU Leather on Cushions and Memory Foam Mattresses) Desert, Midnight, or Storm Decor Packages that include Fiber-Granite Countertops, Premium Vinyl Flooring, and Cloth Uphostery on Cushion (Options available for Upraded PU Leather on Cushions and Memory Foam Mattresses)
Electric
Legacy Elite
12V USB Charging Outlets
12V USB Charge Station 12V USB Charge Station
Interior 120V Outlets
120V Outlets on GFCI Protected Circuit 120V Outlets on GFCI Protected Circuit
Exterior 120V Outlets
Battery Converter/Charger
45 AMP Converter with Battery Charger 45 AMP Converter with Battery Charger
Solar Package
Option Solar Pro Package Integrated 240 Watt Solar Panels with Charge Controller, Two (2) 6V AGM Deep Cycle Batteries, and a 2000 Watt Pro Inverter(Included in Platinum Series)
Upgrade Packages Available.
Option Solar Pro Package Integrated 400 Watt Solar Panels with Charge Controller, and a 2000 Watt Pro Inverter, Four (4) 6V AGM Deep Cycle Batteries(Included in Platinum Series)
Inverter
Option - 2000W Pro Inverter Available Option - 2000W & 3000W Pro Inverters Available
Power Cord
30 Amp Power Cord 30 Amp Power Cord
Kitchen
Legacy Elite
Cooktop
2-Burner LP Cooktop 2-Burner LP Cooktop
Refrigerator
2-Way Refrigerator (12V, 120V) 2-Way Refrigerator (12V, 120V)
Microwave
Stainless Steel Microwave. (Option Interior Add-Ons Package with Microwave Convection Oven)(Included in Platinum Series) Stainless Steel Microwave. (Option Interior Add-Ons Package with Microwave Convection Oven)(Included in Platinum Series)
Cabinetry
Acrylic Faces with Custom Designed Soft Close Storage Drawers with Dovetail Joints Acrylic Faces with Custom Designed Soft Close Storage Drawers with Dovetail Joints
Bathroom
Legacy Elite
Bath Type and Features
Wet bath - Molded Vanity with Waterproof Toiletry Storage and Towel Bar, Chrome Faucet with Pull Out Shower Wand. (Option Interior Add-Ons Package for Shower Track and Curtain)(Included in Platinum Series) Wet bath - Molded Vanity with Waterproof Toiletry Storage and Towel Bar, Chrome Faucet with Pull Out Shower Wand. (Option Interior Add-Ons Package for Shower Track and Curtain)(Included in Platinum Series)
Toilet
Low Profile Toilet With Porcelain Bowl. (Option for Composting Toilet is Available) Low Profile Toilet With Porcelain Bowl. (Option for Composting Toilet is Available)
Entertainment
Legacy Elite
TV
120V 24" Flat Screen LCD TV (requires Inverter) 120V 24" Flat Screen LCD TV (requires Inverter)
DVD, AM/FM/CD Head Unit with Speakers
AM/FM Radio, Bluetooth®, HDMI, DVD, MP3, and CD-R/ RW Playback with Custom Mounted Speakers x4 AM/FM Radio, Bluetooth®, HDMI, DVD, MP3, and CD-R/ RW Playback with Custom Mounted Speakers x4
Cable/Satellite TV Hookup
Cable/Satellite Ready with Extra Dual Exterior Coax for TV - Option Electronics Package with Omni-Directional Antenna(Included in Platinum Series) Cable/Satellite Ready with Extra Dual Exterior Coax for TV - Option Electronics Package with Omni-Directional Antenna(Included in Platinum Series)
Safety
Legacy Elite
Detector Alarms
Fire Extinguisher, Carbon Monoxide, Smoke and LP Detectors Fire Extinguisher, Carbon Monoxide, Smoke and LP Detectors
See an Oliver Travel Trailer
Are you ready to create the perfect travel companion?
Find an Oliver in your area available for a personal tour and start planning your next adventure!
Get Started
graduation-hatfilm-play
