Camper Trailer
2024 Legacy Elite II
The Oliver Legacy Elite II is our largest camper trailer. This tandem axle model measures 23' 6" in length and has an insulated double-hulled fiberglass shell, making it all season camping ready. The Legacy Elite II is available in standard or twin bed floor plans, with a complete kitchen and a full bathroom that includes a toilet, vanity, sink, and shower.
Legacy Elite II trailers have many standard features, and if you want more, look at our new premium and platinum packages for an even greater camping experience.
Specifications
Floorplan Layouts
Standard Floorplan
The standard floorplan features a spacious rear table area that comfortably accommodates up to 6 people, and the table area and side dinette easily convert into beds.
Side Dinette Converts To A 76″ X 25″ Bed
Twin Bed Floorplan
The twin bed floorplan offers the convenience of two rear twin beds, equipped with a nightstand and an extra storage drawer. The side dinette also converts into a bed.
Standard Features Base Model Features & Components
The Oliver Legacy Elite II comes equipped with an array of standard features that are sure to exceed your expectations. Additional features include LED lighting, a bluetooth sound system, and ample storage space throughout. With the Legacy Elite II, you'll have everything you need to enjoy your travels in style and comfort.
Hull Features | |
Full Custom Molded Interior and Exterior Insulated Shells | Standard |
Transportation Grade Gel-Coat with UV Protectants | Standard |
Custom Molded Fiberglass LP Cover | Standard |
Custom Molded Fiberglass Spare Tire Cover | Standard |
Plumbing, Holding Tanks and Drain Pipes enclosed between shells with heat to diminish freezing | Standard |
32 Gal. Design Capacity Fresh Water Tank | Standard |
32 Gal. Design Capacity Grey Water Tank | Standard |
15 Gal. Design Capacity Black Water Tank with pressure flushing system for the Tank | Standard |
Chassis Features | |
Heavy Duty Anode Protected Aircraft Grade Aluminum Frame | Standard |
Dexter E-Z Flex Suspension | Standard |
Quad Gas Shocks on Dual Dexter Leaf Spring Nev-R-Lube Axles with “Nev-R-Adjust” 10″ Electric Brakes for exceptional control and braking | Standard |
Premium Aluminum Rims with 10-ply Tires | Standard |
Full Size Spare Tire with Aluminum Wheel Rim | Standard |
7,000 Lb. Cast Iron Bulldog Hitch | Standard |
Black “Rock Guard” Wheel Well Lining | Standard |
Hide-Away Aluminum Storage Bumper with Black/Grey Water Drain Attachment Located Inside | Standard |
Exterior Features | |
20 Lb. LP Tanks x2 | Standard |
Fresh Water Fill Hook-Up | Standard |
City Water Direct Hook Up | Standard |
Fold Up Aluminum Double Entry Steps with Grip Tape | Standard |
Custom Enclosed Slide-Out Battery Storage – Includes Group 27 Deep Cycle 12V Batteries x4 | Standard |
Marine Grade Shore Power Connection with 25′ Cord | Standard |
Outside 120V GFI Protected Outlet w/ Cover | Standard |
Exterior LED Ground Lighting | Standard |
LED Brake Lights | Standard |
LED Marker Lights | Standard |
High Mount Porch Lights x2 (1 on Each Side) | Standard |
Custom Rear High Mount Oliver Sign | Standard |
Convenient Exterior Entry Handgrip | Standard |
Powered Pro Awning with LED Light Strip, Wind Sensor, Remote, & Upgraded Canvas | Standard |
Outside Wash Station | Standard |
Three Point Power Stabilizing System | Standard |
Sliding Thermal Pane Windows with Sliding Screens x4 | Standard |
Propane Easy Access Port | Standard |
Interior Features | |
Fiber-Granite Countertops, Tables, and Accents | Standard |
Full Surround Over-Head Lighted Storage Compartments | Standard |
Lighted Full Height Wardrobe Closet | Standard |
EZ Winterizing System | Standard |
MaxxFan Deluxe Remote Control RV Ventilator System | Standard |
2 Way Self Igniting Water Heater, DSI 6 Gal | Standard |
Fresh Water Pump 55 PSI, 3.0 GPM | Standard |
Dometic High Efficiency A/C (Approx. 11,000 BTU) Unit & Wall Mount Thermostat | Standard |
LP Ducted Furnace | Standard |
Monitoring System for Tanks and Batteries | Standard |
White Day/Night Window Treatments (Excludes Bathroom) | Standard |
Overhead LED Lights | Standard |
LED Courtesy Floor Lights | Standard |
Reading Light Package | Standard |
Frosted Upper Cabinet Doors in the Cabin and Bathroom | Standard |
Water Accumulator | Standard |
120-Volt Receptacles | Standard |
12V/5V Dual Charging Stations | Standard |
Dinette, Seating, Sleeping and Storage Features | |
Side Dinette (seats 2) Converts to Single Bed | Standard |
Standard Floorplan Rear Dinette (seats 5) Converts to King Bed or Twin Bed Floor Plan Rear Beds | Standard |
Kitchen Features | |
Flush Mount 2x LP Burner Stove | Standard |
2-Way Compressor Refrigerator (12V, 120V) | Standard |
High Rise Swivel Faucet | Standard |
Custom Designed Storage Drawers with Dovetail Joints | Standard |
Stainless Steel Microwave | Standard |
Bathroom Features | |
Molded Vanity with Toiletry Storage | Standard |
Dometic 311 Toilet (Low Profile with Porcelain Bowl) | Standard |
Exhaust Fan | Standard |
Brushed Nickel Faucet with Pull Out Shower Wand | Standard |
Sliding Frosted Privacy Window with Screen | Standard |
Mirror Tinted Door | Standard |
Waterproof Toilet Paper Compartment | Standard |
Towel Bar and Hook | Standard |
Central Heat Vent | Standard |
Safety Features | |
Fire Extinguisher | Standard |
Smoke Detector with Alarm | Standard |
Carbon Monoxide Detector with Alarm | Standard |
LP Leak Detector with Alarm | Standard |
Oversized Emergency Egress Window with Screen | Standard |
Electric Features | |
120V Outlets on GFI Protected Circuit | Standard |
Progressive Industries EMS Surge Protector | Standard |
Converter with Built in Charge Wizard | Standard |
Multiple Charging Stations, 12V DC marine-grade female socket & dual USB 5V adapters | Standard |
Exterior Plug & Play Port for Portable Solar Panels (Requires Factory Installed Solar Package) | Standard |
Entertainment Features | |
24” Flat Screen LCD TV (120V, requires Inverter) | Standard |
Radio with FM & AM Dual Zone Audio Output, CD/DVD/MP/WMA/MP4, USB, Bluetooth & Remote Control | Standard |
Custom Mounted Speakers x4 | Standard |
Dual Exterior Coax for Portable Satellite/Cable | Standard |
Go Beyond Camp SitesExtend Your Stay & Your Enjoyment
We have taken the top requested features from our previous year's model's add-ons and upgrades and put them into our new premium and platinum packages to enhance your camping experience and extend your stay. These improved packages help make the most of your time outdoors by extending your staying power and enhancing the comforts of your home on wheels.
Walkthrough Video
Take the Factory Tour
Find an Oliver Near You
Find out how below.
