Oliver Travel Trailers
Compare Oliver, Airstream & Escape Travel Trailers
How does Legacy Elite II Compare to
Airstream, Escape, and NuCamp RVs
There are various ways to determine which unit is best for you, and it can be an overwhelming decision.
We have done most of the comparative research for you, and here is what we have found out about how Oliver stacks up to the Airstream, Escape, and NuCamp RVs. See the comparative table below for campers similar to other leading brands.
Be sure to see all the Oliver Owners' Reviews.
Hull
Airstream Flying Cloud 23' FB
Escape 21'
NuCamp Avia
Body
Four-piece Molded Fiberglass With Insulation Between Shells Riveted Aluminum Two-piece Molded Fiberglass Lamilux® 4000 Fiberglass Skin, Aluminum Structure w/ Azdel® Sidewalls
Insulation
Double Hull, Thermal Break with Insulated Double-Sided Radiant Barrier Polyethylene Bubble + Radiant barrier + Vapor Barrier + Air Gap Barrier. EcoBatt® Fiberglass Insulation Rolled Foam - Option - Extra insulation / Heat pads with Spray Foam Foiled Double Bubble Insulation
Floor Plans
Standard (75" x 79" Bed) or Twin Bed Floor Plans Three Floor plans - 23FB, 23CB and 23CB Bunk One Floor Plan One Floor Plan
Exterior Length
23' 6" 23' 9" 21' 4" 28'
Exterior Height
9' 7" 9' 9" 8' 7" 9' 10"
Exterior Width
7' 8' 7' 4" 7' 4"
Interior Height
6' 6" 6' 7.5" 6' 4" 6' 4"
Interior Width
6' 7" 7' 7" 6' 8" 7' 1"
Dry Weight (Base)
4,900 lbs. 4,806 lbs. 3,365 lbs. 5,185 lbs.
GVWR
7,000 lbs. 6,000 lbs. 5,000 lbs. 7,000 lbs.
Net Carrying Capacity
2,100 lbs. 1,194 lbs. 980 lbs. Not Specified
Fresh Water Tank Capacity
Design Capacity 32 Gal. 39 Gal. 28 Gal. 43 Gal.
Grey Tank Capacity
Design Capacity 32 Gal. 30 Gal. 28 Gal. 39 Gal.
Black Tank Capacity
Design Capacity 15 Gal. 18 Gal. 22 Gal. 43 Gal.
Water Heater
Suburban 2-Way Self Igniting 6 Gal. Water Heater, DSI - Option Truma AquaGo® Comfort Tankless Heater 2-Way, 6 Gal DSI 6 Gal DSI (LP Only) - 2 Way Option ALDE® System
Chassis
Flying Cloud 23' FB
Escape 21'
NuCamp Avia
Axles
Quad Shocks On Tandem 3,500 Lb. Dexter Leaf Spring Axles with Nev-R Lube Hubs Torsion Axle Suspension High Lift Axle Dexter Axle
Brakes
"Nev-R-Adjust®" 10" Electric Brakes "Nev-R-Adjust®" Brakes Electric Brakes Dexter
Front Tongue Jack
Electric Powered Hitch Jack Electric Powered Hitch Jack Manual Hitch Jack Electric Powered Hitch Jack
Stabilizer Jacks
Electric Powered Manual Manual Electric Powered x4
Wheels
Premium 10-ply Tires on Aluminum Rims with Black "Rock Guard" Wheel Well Lining 15" Goodyear® ST225/75R15 on Aluminum Rims 15" Radial Tires on Steel Rims with Mud Flaps - Option Aluminum Rims 15" Aluminum Wheels
Spare Tire
Full Size Spare Tire with Aluminum Rim Spare Tire with Steel Rim - Full Size Spare Tire with Steel Rim - Full Size Equipped with Spare Tire
Hitch Connection
7,000 Lb. Cast Iron Bulldog Hitch Standard Trailer Hitch Standard Trailer Hitch Standard Trailer Hitch
Frame
2" x 5" Box Tube Aluminum Frame Steel With Aluminum Skin Underbelly 3" Box Steel Aluminum
Rear Bumper
Hide-Away Brushed Aluminum Storage Bumper with Black/grey Water Drain Hose Polished Bumper with Storage Box Steel Molded Trim
Exterior
Flying Cloud 23' FB
Escape 21'
NuCamp Avia
Furnace
Truma VarioHeat Furnace 18K BTU Furnace 12K BTU Furnace ALDE® Radiant Heat 11,000-18,700 BTU
Air Conditioner
Dometic High Efficiency A/C (Aprox. 11,000 BTU) Unit and Wall Mount Thermostat (Can Operate with a 3000W Generator) - Optional Truma Aventa available. Quietstream™ A/C w/ Heat Pump and Electronic Thermostat 13,500 BTU Option 15,000 BTU
Exterior LP Gas Port
Exterior LP Service Ports Available for Front and Rear (Option) Exterior LP Quick Connect Service Port Option N/A
Outside Wash Station
Standard Standard Option Standard
Battery Storage
Custom Enclosed Slide-Out Battery Storage (Fits up to 4x batteries) Battery Box on Tongue (Fits 2x Batteries) Storage Compartment Under Interior Seat Fits 1x Battery. (Optional Upgrade To Fit 2x Batteries) Front Access Hood
Deep Cycle Batteries
Includes 4x Group 27 Deep Cycle 12v Batteries. Optional 6V AGM or Lithium Batteries Upgrades Available. 2x Deep Cycle Battery Group 24 w/ Converter Deep Cycle Batteries 1x Group 27 Deep Cycle Battery 2x 6V AGM Batteries
Propane Gas Tanks
20 Lb. x2 Lp Tanks (Option Upgrade To 30 Lb. Tanks) 30 Lbs. x2 LP Tanks 20 Lb. x2 LP Tanks 20 Lb. x2 LP Tanks
Exterior Lighting
High Mount LED Porch Lights, LED Ground Lights, LED Rear Brake and Backup Lights. Custom Rear High Mount LED Oliver Sign. LED LED Exterior Porch Lights 2x. Rear Upper LED Brake, Signal Lights and LED Marker Lights LED Utility Lighting & Marker Lights, Lighted Entry Handle w/ Motion Sensor
Awning
Standard 16ft. Powered Pro Awning that includes wind sensor, upgraded canvas, and remote. Additional Awning on Street Side is also available Manual ZipDee® Patio Awning with Sunbrella® Fabric 13' Dometic Power Awning 16' Cassette Awning w/ Bluetooth® Control
Windows
4x Sliding Thermal Pane Windows with Sliding Screens and Larger Rear Emergency Egress Window Tempered Tinted Windows Non-Thermal Pane Screened Windows Stargazer Windows
Steps
Fold Up Aluminum Double Entry Steps with Grip Tape Aluminum Entry Step Single Steel Step Project 2000 Aluminum Entry Step
Interior
Flying Cloud 23' FB
Escape 21'
NuCamp Avia
Interior Lighting
LED Lights LED Lights LED Lights LED Lights
Window Shades
Day/Night Window Treatments (Excludes Bathroom) Aluminum Roller Blinds Draw Down Window Shades w/ Valances Curtains
Digital Monitoring Systems
See Level II Monitoring System for Tanks and Battery Voltage Probeless Tank Monitoring System Monitor Panel w/ Holding Tank Level Indicator and Battery Fill Level Monitor Screen for Tanks and Battery
Vent Fan
MaxxFan Deluxe RV Ventilator System with Remote Control Fantastic© Fan x2 w/ Thermostat MaxxFan Fan-Tastic© Fan x4
Floor Construction
Gel-Coat Over Fiberglass Molded Inner Shell 5/8″ WBP Tongue-and-Groove Wood Floor Plywood Flooring Not Specified
Interior Wall Construction
Gel-Coat Over Fiberglass Molded Inner Shell Complete Aluminum Interior Walls and Ceiling Vinyl Headliner/wall Covering Over Wood Frame Aluminum Structure w/ Azdel® Sidewalls
Countertops
Gel-Coat Over Fiberglass Laminate Galley Top Formica Counter and Tabletops Laminate Galley Top
Flooring
Seamless Vinyl Floorings Seamless Vinyl Flooring Linoleum Flooring Vinyl Flooring
Upholstery
Premium Cloth Upholstery (Option for PU Leather Upgrades) Ultraleather™ (Synthetic) Cloth Pleather (Appears to be - Not specified)
Electric
Flying Cloud 23' FB
Escape 21'
NuCamp Avia
12V USB Charging Outlets
12V USB Charge Station 12V USB Charge Station 12V USB Interior Outlet 12V USB Interior Outlet
Interior 110V/120V Outlets
110V Outlets on GFCI Protected Circuit 110V Outlets 110V Outlets 110V Outlets
Exterior 110/120V Outlets
Battery Converter/Charger
45 AMP Converter with Battery Charger 55 AMP Converter with Battery Charger 55 AMP Converter with Battery Charger Not Specified
Solar Package
Option 400W Solar Panel with Charge Controller in some Power packages Prewired (Option 90W or 180W Solar Package with AGM Battery) (Option 190W Solar Panel with Charge Controller) Top-Line Solar Package
Inverter
Optional 2000W Inverter or 3000W Inverter with Lithium Pro Package Standard 1000 Watt Inverter Inverter with/without Transfer Switch - Option 1200-Watt Inverter
Power Cord
30 Amp 25' Power Cord 30 Amp 25' Power Cord 30 Amp 25' Power Cord (Option) Not Specified
Kitchen
Flying Cloud 23' FB
Escape 21'
NuCamp Avia
Cooktop
2-Burner LP Cooktop 3-Burner Cooktop 2-Burner Cooktop 3-Burner Cooktop
Refrigerator
2 Way Refrigerator (12V, 11OV) 2-Way, 5 Cubic ft. Refrigerator 3-way 6 Cubic ft. Dometic Refrigerator 3-Way 5.0 cu. ft. Refrigerator / Freezer
Microwave
Stainless Steel Microwave (Option Convection Microwave Oven) Microwave (Option Convection) Microwave (Option) Convection / Microwave Oven w/ Air Fryer
Cabinetry
Acrylic Faces with Custom Designed Storage Drawers with Dovetail Joints Lite-Ply® Laminated Interior Cabinetry Custom Wood Interior European-Styled Cabinetry
Bathroom
Flying Cloud 23' FB
Escape 21'
NuCamp Avia
Bath Type and Features
Wet bath (Option Shower Track for Curtain) Dry bath Wet bath Dry Bath
Toilet
Porcelain Toilet (Option For Nature's Head Composting Is Available) Porcelain Toilet Thetford Toilet Porcelain Toilet
Entertainment
Flying Cloud 23' FB
Escape 21'
NuCamp Avia
TV
24" Smart LCD TV 22" LED HD TV x2 Not Included 24" Flat-Screen TV - Kitchen
28" Flat-Screen TV - Bedroom
DVD, AM/FM/CD Head Unit with Speakers
Furrion AM/FM Radio, Bluetooth®, HDMI, DVD, MP3, and CD-R/ RW Playback with Custom Mounted Speakers x4 Clarion Stereo: FM/AM/CD Radio with Bluetooth® (in/out) & Blu-Ray™ DVD Player Stereo/DVD Speakers (Option) Premium Sound System w/ Subwoofer, Premium Exterior Speakers
Cable/Satellite TV Hookup
Cable/Satellite Ready with Extra Dual Exterior Coax for TV Cable / Satelite / TV Antenna Hookups are standard TV/Cable Ready with 120V Outlet (Option) Cable / Satelite Connection
Safety
Flying Cloud 23' FB
Escape 21'
NuCamp Avia
Detector Alarms
Fire Extinguisher, Carbon Monoxide, Smoke & LP Detectors Fire Extinguisher, Carbon Monoxide, Smoke & LP Detectors Fire Extinguisher, Carbon Monoxide, Smoke & LP Detectors Fire Extinguisher, Emergency Exit Window, Smoke Alarm, Carbon Monoxide, CO & LP Gas Alarm
Pricing
Flying Cloud 23' FB
Escape 21'
NuCamp Avia
Starting Price
$73,500 $94,400 $51,900 CDN (Approx. $42,195 USD) $60,000 (No longer building newer models)
See an Oliver Travel Trailer
Are you ready to create the perfect travel companion?
Find an Oliver in your area available for a personal tour and start planning your next adventure!
Get Started
graduation-hatfilm-play
