Compare Legacy Elite and Other Travel Trailers
See How the Legacy Elite Compares to the
Airstream & Other Travel Trailers
We put together a comprehensive comparison on the latest Fiberglass Travel Trailer to join the ranks with the rest of us! We've done the research for you and we wanted to share with you what we found.
Hull |
Legacy Elite |
inTech Sol |
Airstream Caravel 19CB |
Airstream Basecamp 20X |
Body |
Four-piece molded fiberglass with insulation between shells | Fiberglass | Riveted Aluminum | Riveted Aluminum |
Insulation |
Double Hull, Thermal Break with Insulated Double-Sided Radiant Barrier Polyethylene Bubble + Radiant barrier + Vapor Barrier + Air Gap Barrier. | Bubble Foil R7 (Walls & Ceiling) | EcoBatt® Insulation | EcoBatt® Insulation |
Floor Plans |
Standard (74" x 52" Bed) | Standard (80" x 60" Queen Mattress) | 1 Floor Plan | 1 Floor Plan |
Exterior Length |
18' 5" | 19' | 19'5" | 20'2" |
Exterior Height - Top of the A/C |
9'" | 9' 5" | 9' 7" | 9' 1.5" |
Exterior Width |
6' 6" | 8' 5" | 8' | 7' 9.5" |
Interior Height |
6' 1" | 6' 5" | 6'7" | 6'7" |
Dry Weight (Base) |
3,700 lbs. | 3,350 lbs. | 4,000 lbs. | 3,400 lbs. |
GVWR |
5,000 lbs. | 4,000 lbs. | 5,000 lbs. | 4,300 lbs. |
Net Carrying Capacity |
1,300 lbs. | 610 lbs. | 1,000 lbs. | 900 lbs. |
Fresh Water Tank Capacity |
Design Capacity 32 Gal. | 28 Gal. | 23 Gal | 23 Gal |
Grey Tank Capacity |
Design Capacity 32 Gal. | 32 Gal. | 29 Gal | 28 Gal |
Black Tank Capacity |
Design Capacity 15 Gal. | 32 Gal. | 18 Gal | 21 Gal |
Water Heater |
Suburban 2-Way Self Igniting 6 Gal. Water Heater, DSI - Option Truma AquaGo® Comfort Tankless Heater | 6 Gal. - Electric or Gas | Tankless On Demand LP Water Heater | Electric/LP Water Heater |
Chassis |
Legacy Elite |
inTech Sol |
Axles |
Dual Shocks on Single 5,200 lb. Dexter Leaf Spring Axle with Nev-R Lube Sealed bearings (Now with Bronze Bushings and Grease Zerks) | Dexter Torsion | Torsion Axle Suspension, Nev-R-Lube® Sealed Bearings | Torsion Axle Suspension |
Brakes |
“Nev-R-Adjust” 12″ electric brakes for exceptional control and braking | Electric Powered | Nev-R-Adjust® Brakes | Nev-R-Adjust® Brakes |
Front Tongue Jack |
Electric Powered | Optional | Electric Powered | Manual |
Stabilizer Jacks |
Electric Powered x2 | Manual Rear | 4 Manual Heavy Duty Stabilizer Jacks, Powered Hitch Jack with Light | 4 Manual Heavy Duty Stabilizer Jacks |
Wheels |
Premium Aluminum Rims with 10-ply Tires with Black “Rock Guard” Wheel Well Lining | ST205/75R15 Tires w/Aluminum Wheels | ST225/75R15 Tires Stylized Aluminum Wheels, | ST235/80R16 Tires Stylized Aluminum Wheels |
Spare Tire |
Full Size Spare with Aluminum Rim | Full Size Spare Tire | Full Size Spare Tire | Full Size Spare Tire |
Hitch Connection |
7,000 Lb. Cast Iron Bulldog Hitch | Standard | Standard | Standard |
Frame |
2" x 5" Box Tube Aluminum Frame | All-Aluminum / All-Tube / Cage Frame | All-Aluminum / All-Tube / Cage Frame | All-Aluminum / All-Tube / Cage Frame |
Rear Bumper |
Hide-Away Brushed Aluminum Storage Bumper with Black/Grey Water Drain Hose | 2” Receiver – 100# Capacity | Polished Bumper with Storage | Polished Bumper with Storage |
Exterior |
Legacy Elite |
inTech Sol |
Furnace |
Truma VarioHeat Furnace | 16K BTU Furnace | Ducted Furnace (16,000 BTU) | Ducted Furnace (14,300 BTU) |
Air Conditioner |
Dometic High Efficiency A/C (Aprox. 11,000 BTU) Unit and Wall Mount Thermostat (Can Operate with a 3000W Generator) - Option for Truma Aventa | Dometic 13.5K BTU Low Profile Air Conditioner | 30 AMP Service Single AC with Heat Pump (13,500 BTU) | 30 AMP Service Single AC with Heat Pump (13,500 BTU) |
Exterior LP Gas Port |
Exterior Quick Connect Ports available for Front and Rear (Option) | LP Quick Connect | Exterior LP Gas Low Pressure Grill Connection | Exterior LP Gas Low Pressure Grill Connection |
Outside Wash Station |
Standard | Standard | Exterior Shower with Hot & Cold Water | Exterior Shower with Hot & Cold Water |
Battery Storage |
Custom Enclosed Slide-Out Battery Storage (Fits Up to 2x Batteries) | Interior Storage Enclosure | Exterior Front Tongue Enclosure | Inside Front Storage Compartment |
Deep Cycle Batteries |
2x 12 V Batteries. Optional AGM and Lithium Battery Upgrades Available. | 1x Deep Cycle 12V Battery | Deep Cycle Battery | Deep Cycle Battery |
Propane Gas Tanks |
20 Lb. x2 LP Tanks | 20 Lbs. Tank x1 | LP (2 – 20 lb. Steel Tanks) with Auto 2-stage Regulator | LP (2 – 20 lb. Steel Tanks) w/ auto 2-stage regulator |
Exterior Lighting |
High Mount LED Porch Lights, LED Ground Lights, LED Rear Brake and Backup Lights. Custom Rear High Mount LED Oliver Sign. | Step Light, Porch Light and Blue Accent Strip Along the Windshield | LED Dimmable Patio Awning Light, Cast Aluminum LED Tail Lights | Cast Aluminum LED Tail Lights |
Awning |
Standard Powered Pro Awning upgrade that includes wind sensor, upgraded canvas, and remote. | Optional 10' Thule awning | Manual Zip Dee® Patio Awning with Sunbrella® Fabric | Optional ARB Awning |
Windows |
3x Sliding Thermal Pane Windows with Sliding Screens and Rear Emergency Egress Window | (8) Tinted Windows w/Shades | Interior Windows and Skylights, Handcrafted Welded Extruded Aluminum Window Frames, Panoramic Front Windows with Blackout Shades, Solar Front Window Protection, Tempered Tinted Windows with Double Cam Latching System | Interior Windows and Skylights, Handcrafted Welded Extruded Aluminum Window Frames, Panoramic Front Windows with Blackout Shades, Solar Front Window Protection, Tempered Tinted Windows with Double Cam Latching System |
Steps |
Fold Up Aluminum Double Entry Steps with Grip Tape | Entry Step | Aluminum Entry Step | Steel Entry Step |
Interior |
Legacy Elite |
inTech Sol |
Interior Lighting |
LED Lights | 12V Ceiling Dome Light, Blue/White Reading Accent Light | LED Interior Lighting with Dimmer, Reading LED Lights | LED Interior Lighting |
Window Shades |
Day/Night Window Treatments (Excludes Bathroom) | Pull Down Roller Shade | Blackout Shades | Blackout Shades |
Digital Monitoring Systems |
Wall Mounted, See Level II Monitoring System for Tanks and Battery Voltage | Tank Monitoring System | Probeless Tank Monitoring System, QuietStream™ A/C with Heat Pump & Electronic Thermostat | Probeless Tank Monitoring System |
Vent Fan |
Maxxair Fan Deluxe RV Ventilator System with Remote Control | Maxxair Fan | Fantastic© Fan with Thermostat & Automatic Rain Sensor, Roof Vent/Fan | Fantastic© Fan |
Floor Construction |
Gel-coat Over Fiberglass Molded Inner Shell | Infinity Woven Flooring | 5/8″ WBP Tongue-and-Groove Wood Floor | 5/8″ WBP Tongue-and-Groove Wood Floor |
Interior Wall Construction |
Gel-coat Over Fiberglass Molded Inner Shell | Aluminum Walls with Sealing Exterior Door | Complete Aluminum Interior Walls and Ceiling | Complete Aluminum Interior Walls and Ceiling |
Countertops |
Luxury Fiber-Granite | Laminate Galley Top | Laminate Galley Top | Laminate Galley Top |
Flooring |
Premium Vinyl Floorings | Infinity Woven Flooring | Seamless Composite Flooring, Seamless Vinyl Flooring | Seamless Vinyl Flooring |
Upholstery |
Premium Cloth Upholstery Options or PU Leather Upgrades | Not Specified | Ultraleather® | Ultraleather® |
Electric |
Legacy Elite |
inTech Sol |
12V USB Charging Outlets |
12V USB Charge Station | 2 USB Ports | 12V USB Ports | 12V USB Ports |
Interior 110V/120V Outlets |
110V Outlets on GFCI Protected Circuit | 2x 120V AC, 12V DC Outlet | 110V Outlets | Pop Up 110V USB and 110V Outlets |
Exterior 110/120V Outlets |
110V Outlets on GFCI Protected Circuit | 110V Outlets | 110V Outlets | 110V Outlets |
Battery Converter/Charger |
45 AMP Converter with Battery Charger | 35 Amp | Included (Unspecified Amp) | Included (Unspecified Amp) |
Solar Package |
Prewired - Optional Integrated 230W Roof Mounted Solar Panel with Charge Controller | Prepped to have a Solar Panel Kit Installed | Solar Pre-wire (3 Rooftop & 1 Front Access Points) | Solar Pre-wire (3 Rooftop & 1 Front Access Points) |
Inverter |
Option - Xantrex Freedom XC 2000W Inverter | 30 Amp 120V Breaker Box w/ 12V Converter - PD4100 | 1000W Pure Sine Inverter | Not Available |
Power Cord |
30 Amp 25' Power Cord | Not Specified | Not Specified | Not Specified |
Kitchen |
Legacy Elite |
inTech Sol |
Cooktop |
2-Burner LP Cooktop | 2-Burner Stainless Steel | 3 Burner Gas Cooktop (20, 22); 2 Burner Gas Cooktop (16, 19) | 2 Burner Cooktop (LP Gas) |
Refrigerator |
2 Way Refrigerator (12V, 11OV) | 3.7 Cu Ft 3-Way | Refrigerator (12v Electric) 4.3 Cu Ft | Refrgerator (LP/Electric) 3.1 Cu Ft |
Microwave |
Stainless Steel Microwave - Option Microwave Convection Oven | 1 Cu Ft Stainless Steel | Stainless Microwave | Optional |
Cabinetry |
Acrylic Faces with Custom Designed Soft Close Storage Drawers with Dovetail Joints | (6) Drawers, (7) Overhead Cabinets, (4) Overhead Cubbies | Handcrafted Italian Lite-Ply Laminated Cabinetry | Handcrafted Italian Lite-Ply Laminated Cabinetry |
Bathroom |
Legacy Elite |
inTech Sol |
Bath Type and Features |
Wet Bath (Optional Shower Curtain) | Wet Bath | Wet Bath | Wet Bath |
Toilet |
Porcelain Toilet - Option For Nature's Head Composting Is Available | Porcelain Toilet | Standard Toilet | Standard Toilet |
Entertainment |
Legacy Elite |
inTech Sol |
TV |
24" Smart LCD TV | 32" TV | LG LED HD TV with Omni Directional Antenna | N/A |
DVD, AM/FM/CD Head Unit with Speakers |
Furrion AM/FM Radio, Bluetooth®, HDMI, DVD, MP3, and CD-R/ RW Playback with Custom Mounted Speakers x4 | Bluetooth Stereo w/(4) Speakers and DVD Player | Blu-Ray™ DVD Player w/(4) Speakers and Subwoofer | N/A |
Cable/Satellite TV Hookup |
Cable/Satellite Ready with Extra Dual Exterior Coax for TV | Cable TV Hookup | Cable TV Hookup | N/A |
Safety |
Legacy Elite |
inTech Sol |
Detector Alarms |
Fire Extinguisher, Carbon Monoxide, Smoke and LP Detectors | Smoke and CO Detector, LP and CO Alarm, Fire Extinguisher | LP, Smoke & Carbon Monoxide Detectors, Fire Extinguisher | LP, Smoke & Carbon Monoxide Detectors, Fire Extinguisher |
Pricing |
Legacy Elite |
inTech Sol |
Starting Price |
$65,500 | $42,539 | $77,300 |
$54,400.00 |
